Miss Fitts
  • 98ciHemi
    • Dec 2008
    • 2425
    #106
    Sweet! Thanks. I'll snag that as soon as I get paid.
    • HillbillySailor2
      • 450
      #107
      Oh, I meant to ask this earlier. What's the difference between the steering column for a manual or power steering car? I thought the difference was in the rack?
      Formerly Shannon (aka: HillbillySailor). 2549 posts.
      • HillbillySailor2
        • 450
        #108
        But if a column is what you're looking for, try this place out.
        We stock 3,000+ OEM rebuilt steering columns for cars and trucks from 1967. Direct fit, easy install, 30-day money-back guarantee. Nationwide shipping.
        • Thumpin455
          • Jan 2010
          • 4753
          #109
          It can sleep here for a bit, and we can possibly get some body work done on it too... scary thought making it shine with a nice glossy coat.
          • 98ciHemi
            • Dec 2008
            • 2425
            #110
            There is a spline difference where the shaft mates to the rack. The power rack has a larger OD. Right the the car has a manual rack and a power column, so the steering is held together with a little jam nut through the shaft. Not particularly confidence inspiring.
              #111
              One of my favorite things to see under the hood of a "rod" is the good old 1/2" drive socket universal joint welded between the column and steering box input shaft.
              • HillbillySailor2
                • 450
                #112
                Thanks for the explanation. Hopefully that column place I posted earlier will be able to help you out.
                • HillbillySailor2
                  • 450
                  #113
                  I got to thinking about this, and I think I might have found a solution for your steering woes...and John sorta gave it to me! Have you considered an universal joint? I don't know what the layout is with regards to the shaft/rack relationship, but a universal joint may be the ticket to meet the different sizes of the shaft and rack spline. Here's a couple of sites to look at....
                  The first one I thought of: Ididit...specfically, their universal joint selection. It gives a general pictorial description of what to use for different applications.
                  We are sorry, but this page cannot be found. If you have any questions or can't find what you are looking for, please contact us . Visit Home Page
                  Once you figure that out, here's the company that makes the u-joints for Ididit. From our prior conversation, I take it that the steering shaft is a different size than the connection on the rack. They sell u-joints with different sized ends. You can pick what you need from their list, providing they have it...
                  Universal Steering JointsHigh-Quality Steering Joints for Precision and DurabilityBorgeson offers high-quality needle-bearing universal steering joints, machined with precision in our factory using state-of-the-art CNC equipment. Available in steel, stainless steel, and aluminum, our universal joints are designed to provide smooth and reliable operation for a wide range of steering applications.Single Needle Bearing Universal Steering JointsBorgeson's single needle bearing steering joints are engineered to operate smoothly at angles up to 35°. For angles exceeding 35°, our double universal joints are recommended. These joints ensure precise control and dependable performance, making them an excellent choice for various vehicle types.Double Needle Bearing Universal Steering JointsFor applications requiring greater flexibility, Borgeson offers double needle-bearing steering joints. These joints can accommodate angles over 35º and up to 70º, providing superior maneuverability. Available in steel, stainless steel, and aluminum, our double universal joints come in all spline and Double-D configurations to meet diverse needs.
                  Hope this helps!
                  • 98ciHemi
                    • Dec 2008
                    • 2425
                    #114
                    Sadly, this project is coming to an end. I wish I had the storage to keep this till I have time, but frankly, I have lost interest. I have a good home for most of the parts including a lot of the rarer Escort specific parts. Between the school, ROTC, the plane, the Tahoe, my bicycle projects, and now the Honda, I have enough on my plate. I can turn this into some cash.
                    I won't be dropping land speed racing, just postponing my participation as a racer until I have the means to build the car I really want.
                    I like the name Miss Fitts too much to not use it, and I have nose art that deserves to be on something, so the Honda will take up the name and the noseart, probably in the next three weeks as I am cleaning it up.
                    • 1trickpony
                      • 1102
                      #115
                      It's a tough pill to swallow. Most all of us have been in your shoes at least once in our life. Some times it's just a timing issue. I am fairly confident that you will be back. I will keep you in mind if I ever need a hot shoe to drive my junkyard special at the mile.
                      Jeff
                      Follow My Build
