Originally posted by convss
View Post
Pintoboy77 Torino Project (Lost in a restoration black hole)
Thanks Gregg and I know what you mean about driving them I love driving my old cars better than my newer truck and like Bruce said half the fun is working on them.Greg & Mendy Dayton, Ohio 2007LH 2008LH 2010LH 2011LH 2012 1st 2 stops 2013LH 2015 1st 2 stops2016LH 2017 first and last stops . 2018 LH ("It's better to be dead and cool than alive and uncool!! Harley Davidson!") -
Got the other two holes in the shock towers filled in tonight I hope the cat that put them in had as much fun putting them in as I had getting them out. The back two where a pain in the A$$.Greg & Mendy Dayton, Ohio 2007LH 2008LH 2010LH 2011LH 2012 1st 2 stops 2013LH 2015 1st 2 stops2016LH 2017 first and last stops . 2018 LH ("It's better to be dead and cool than alive and uncool!! Harley Davidson!")Comment
Worked on the Torino got the frame repaired.
Next problem windshield area looks worse in the pictures than what it really is.
Dude...you need a 347 stroker with under-manifold nitrous, dressed to look like a stock 302. :DOriginally posted by pintoboy77 View PostI started off with a 5.0 with EFI I'm now dropping the EFI for a intake and carb ,but I'm keeping the AOD trans and 355 rear gears.
The motor is out of a 90 Crown Vic I'm in the process of rebuilding I'm going to put in a new roller cam two stage over stock this changes it to a 5.0 HO and may bore it .030 over for a few more horses not to radical I also am going to run AC on this car.John
2007-2008-2009-2010-2011 Long Hauler
2024-2025 Long HaulerComment
Bruce I do have a donor car. The drivers side looks to be Ok,but the pasenger side looks to have rust,but hard to tell. This car did'nt look rusty until I pulled the windshield out. I may just move onto the three small places in the floor pans and come back to this after I pull the other car apart.Originally posted by cobra View Poston the window, do you have a doaner car or are you going to make it from scratch?Greg & Mendy Dayton, Ohio 2007LH 2008LH 2010LH 2011LH 2012 1st 2 stops 2013LH 2015 1st 2 stops2016LH 2017 first and last stops . 2018 LH ("It's better to be dead and cool than alive and uncool!! Harley Davidson!")Comment
Jarlaxle that sounds like a cool set up I will have to give that some thaught I still have a ways to go before I'm ready for the engine. ThanksGreg & Mendy Dayton, Ohio 2007LH 2008LH 2010LH 2011LH 2012 1st 2 stops 2013LH 2015 1st 2 stops2016LH 2017 first and last stops . 2018 LH ("It's better to be dead and cool than alive and uncool!! Harley Davidson!")Comment
That windshield area is nothing to be concerned about, easy fix. Is that a piece of Unistrut you are using for a drag link?Comment
I don't really get to upset about much on this car I figure I've got a 50% chance of doing it right. An yes that is a piece of unistrut as a drag link,but it's just temperary the guys before me really stripped this thing I bought it mainly as a shell and did'nt get much more,but the under body is in much better shape than my other car.Originally posted by Wideglid80 View PostThat windshield area is nothing to be concerned about, easy fix. Is that a piece of Unistrut you are using for a drag link?Last edited by pintoboy77; January 16, 2012, 02:13 PM.Greg & Mendy Dayton, Ohio 2007LH 2008LH 2010LH 2011LH 2012 1st 2 stops 2013LH 2015 1st 2 stops2016LH 2017 first and last stops . 2018 LH ("It's better to be dead and cool than alive and uncool!! Harley Davidson!")Comment
Started Pulling the cowl apart tonight this is going to be fun must have been someones first day on the spot welder, but the good news is I think I have enough good cowl parts to make one good one.
Last edited by pintoboy77; January 16, 2012, 08:03 PM.Greg & Mendy Dayton, Ohio 2007LH 2008LH 2010LH 2011LH 2012 1st 2 stops 2013LH 2015 1st 2 stops2016LH 2017 first and last stops . 2018 LH ("It's better to be dead and cool than alive and uncool!! Harley Davidson!")Comment
Got the cowl torn apart tonight the top part is junk the bottom is repairable it's going to take a little welding and some fab work,but I can save it. I'm petty sure the top part on my other car is good,but won't know till I get it apart.
Found a little present from a former tenent.
Passenger side not to bad.
All in all I have seen worse on these cars.
Last edited by pintoboy77; January 19, 2012, 06:29 PM.Greg & Mendy Dayton, Ohio 2007LH 2008LH 2010LH 2011LH 2012 1st 2 stops 2013LH 2015 1st 2 stops2016LH 2017 first and last stops . 2018 LH ("It's better to be dead and cool than alive and uncool!! Harley Davidson!")Comment
I don't have any skills it's just a trick it's all done with mirriors.HaHa Thanks.Originally posted by convss View PostLooks like you are making good progress, Greg! Keep up the good work! I wish I had your skills!Greg & Mendy Dayton, Ohio 2007LH 2008LH 2010LH 2011LH 2012 1st 2 stops 2013LH 2015 1st 2 stops2016LH 2017 first and last stops . 2018 LH ("It's better to be dead and cool than alive and uncool!! Harley Davidson!")Comment
