Chassis cert and comp license
  • bgblockelcamino
    • Dec 2012
    • 100
    Been wondering if plan on running faster than 10.0 I would assume need chassis cert and license. Now would an ihra be legal for drag week? As most local places are ihra near here would be easier. But if wont be accepted I will plan to for nhra license.
  • nplewniak
    Tire Chirper
    • Feb 2013
    • 99
    i believe it is nhra safety cert and specs and ihra or nhra license don't quote me on this tho. I have the same issue
    • lun40119
      • Jan 2011
      • 1564
      I have an IHRA license. Last year, I had the crossover license stuff filled out and the physical done, only thing left to do was mail it in with the check. I brought all of that and a check in case someone made a stink about it at tech. Nobody did. Just be prepared......
      Yes you will need a chassis cert...
      Team Clueless
      1st Place SB/NA DW12
      2nd Place SB/NA DW11
      • AdvAutoBob
        • Oct 2012
        • 558
        according to the official rules, the chassis must be NHRA certified, but you can have a license from either NHRA or IHRA - go figure
        DW2013 - DNF (Gateway - trans failure)
        DW2014 - SR BB/PA class winner!
        DW2015 - Finished in 1 piece (for once!)
        DW2016 - Still "Fox Free" ;)
          The Certs are not up to Hot Rod it is up to the Tracks all of and each you could be inspected 5 times if they want! That's why Hot Rods inspection is held separate.
          • bgblockelcamino
            • Dec 2012
            • 100
            Sounds like would be easiest to just plan all nhra cert and license to play it safe.
            • MR P-BODY
              • Apr 2012
              • 2359
              Most(if not all) NHRA tracks do NOT accept the IHRA cert or licence...
              BUT the IHRA DOES in most cases
