Hoping one of you experts might be able to point me in the right direction here...
I am fighting a vibration and would appreciate any ideas you guys could throw at me. Its not very noticable at speeds under 60 (where I do most of my driving) but rears its head the faster you go. At 70-80 mph its really bad. It is not RPM related at all, all speed related. It definately seems to come from the rear of the car.
The vibration started after I swapped to a junkyard Thunderbird Turbo Coupe 8.8 rearend (went from stock 2.73 gears to 3.73), changed springs (lowered the car quite a bit), and added CHE lower control arms. It has the brake rotors that came with the axle but I had them "turned" at my local NAPA.
I have done the following since the vibration started (some to try and cure the vibration, others just mods):
1.) rearend completely rebuilt, every bearing, etc
2.) I recently changed to T5 manual trans from AOD (including crossmember, trans mount, etc)
3.) new motor mounts
4.) tires rebalanced twice
5.) exhaust changed
6.) added CHE adjustable upper control arms and set pinion angle (I have had two shops go through the rear axle, one guy specializes in drag car/race car rearends and could find nothing wrong with the axle)
7.) changed u-joints
8.) cussed, stomped feet, turned red, hit things, etc
9.) took driveshaft to driveline specialty shop and had them check balance...balanced out 100% perfect
10.) put stock rear springs in, still had vibration
So I am at a loss...I've read that the two most common speed-related vibration problems are 1.) tires or 2.) warped/bad brake rotors. As mentioned earlier, I have had the tires rebalanced twice and the original TC brake rotors were "turned" when I swapped in the axle. Could the rotors be warped, bent, or somehow messed up enough to cause a vibration as described??
Any ideas? I don't want this thing to shake apart on HRPT...
HELP ME!!! lol.
5.) exhaust changed
HELP ME!!! lol.
