Rescue rig project
  • OldMachinist
    • 449
    #241
    I had an '84 Blazer and the windows were slow but always worked. Do you drive your pickup enough for this to be a problem? If your Hummer is a rescue rig, how much are you going to use this? DD?
      • 32251
      #242
      Originally posted by JOES66FURY View Post
      is it both or just one? I would hot wire the motor to see if it speeds up, that will tell you right now if the motor is worn or there is a power supply problem. My 2 cents...
      try to bypass the switch and see if maybe the switch is the culprit....
      switch and contacts are both new....
        • 32251
        #243
        the window stopped working when it was 20* here (and mostly down).... but they stop at about 3/4 of the way down and won't go without help - in all other positions they're slow.... it really does seem like they're not getting enough power - given that I can run a welder off the inverter, I know the charging system (give or take a volt) is up to snuff.
        okay, and I admit it - I'm addicted to cars.... does that mean I have to go to meetings? "Hi, I don't even have a real name, I'm SuperBuickGuy, and I have a problem with cars"
        I actually have 3 rescue rigs.... a H3, a pickup and a bmw
        • yellomalibu
          • 3631
          #244
          LoL. I have a friend who has that problem with guitars... he really needs help!
          • Mater
            • 2347
            #245
            if you have a problem then i really have a problem
            "hello i am Mater and i am addicted to crappy 90's FWD mopars and GMs"
            i have had 30 of them thirty no one should ever have that many FWD cars ever lol
              #246
              I don't think you'll get much help without telling them if it's electrical or mechanical and what kind of problem you are having. For what it's worth, if you can't fix it with a hammer, you have an electrical problem.
                • 32251
                #247
                While I admit my problem with cars, I'm not ready or willing to change.... so there will be no steps here
                  #248
                  how hard is it to make them manual crank up windows?
                  The guy that just bought my nephews truck (finally) stated that one of the reasons he wanted it was because
                  "it doesn't have all that power crap or 4x4 that I don't need or want"
                  I'm just happy to have the money than the truck - what's that saying? It's easier to store dollars than vehicles... something like that.
                  it would be a shame to see you give up on this beast with all you've put into it.
                  and
                  it would be as hame to see you beat the crap out of your H3 that's supposed to be your daily driver...
                  focus!
                  (pot - meet kettle)
                    • 32251
                    #249
                    and
                    focus!
                    (pot - meet kettle)
                    It's far easier to run a positive and a ground than swap in manual cranks....
                    There may be a plan to put 40s under the diesel and make it my winter rescue rig (as opposed to a spring, fall or summer rescue rig - which there are plans for those to come into being as well) .... oh yeah, and seat heaters, navigation and a good dvd combo for those exciting missions where I'm sitting on a hilltop being radio relay.
                    the DD is supposed to be the Corvette.... which, should it chose to stop snowing/raining sideways, is going to happen
                    • Caveman Tony
                      • Aug 2010
                      • 1544
                      #250
                      Hey, SBG, how do the undersides/insides of the fenders look? I ask b/c you live in a wet climate, and so do I...
                      My '74 is an AZ truck, but it is showing initial signs of tin worms in certain areas... my plan is diaper-load of Rust-O-leum on the underside, inside of fenders, frame etc... and some of it will simply get sliced off to fit tires.
                        • 32251
                        #251
                        mine are solid. They don't use salt on the roads here, and we don't have sun to bake the paint off.
                        They will rust out if they leak from the windows because water will never dry out and eventually will hit bare metal.
                        The only issue my truck had was water got trapped under the front window seal and rusted it out at the drain holes. A bit of mig plus everdure filler and it's fixed (on yeah, and copious amounts of window glue - the type they use to glue windows in place).
                          #252
                          Same here down in OR.. only time inner fenders rot is if they fill with vegtable matter and sit..
                            #253
                            SO - did new wiring fix it?
                            what's the amp draw?
                            is the old fusebox the problem?
                            I got a jensen touchscreen radio from crutchfield that plays dvds on screen, and came with a backup camera - for $275.
                            Plus all the standard, cd/mp3/ipod input/usb input etc.
                            wire the parking brake "nanny switch" wire to ground - play dvds while driving
                            wire the "reverse light switch" wire to a toggle switch - turn on camera whenever you want.
                            This is a double DIN size radio - not sure where you'd fit it in a single DIN dash - but it would look right at home in a stainless console under the dash. Put the boost and trans oil temp gauges in another stainless panel where the factory radio was.
                              • 32251
                              #254
                              Haven't had a chance to do anything other than breath recently.... maybe tonight I can check.
                              That radio is interesting, but for the BMW
                              I have a portable DVD player that runs off the cig lighter
                                • 32251
                                #255
                                So I finally said enough with the current alternator and bought a 108 amp powermaster - oh what a difference, windows even work right
