Not full throttle
I thought I was full throttle...
making final cable connection at carb, making it neat, I realized I am about .5 inch too short. It is a bellcrank type ratio, the fianl for throttle. at idle up to about 90%..then the pedal is on the floor. all is right, except the pedal end (could do either way to fix it, but no)
could be as simple as the carpet at the pedal end. That is the end I attack from next.
To find a hard mount for cable, looking like it was meant to be, not buy any extras at the carb, using oem of both carb and car..I choose the pedal end for the last half inch.
A loooong pull for the monojet.
I was chugging along, to get to my place is as weirdly geographic as san francisco. A choice of three greater than ten percent hills to climb. A cough of something new, otherwise dialing in nice... I let it go down to 1500rpm in second. for 108ci and 2300 pounds, it climbed like a little cat diesel.
the one big throttle has some things to learn..
wide open on the monojet has an extra push, I found that in the manual. Looking forward to what this does next.
At <40mm throttle (oem subaru spfi) it peaked at 115mph and the 1990s ecu stopped it. I'll know the gain in the curve by guessing, just romping to a legal 75-80 local highway with the 43mm.
