What's the optimal weight distribution for an LSR car?
  • Caveman Tony
    • Aug 2010
    • 1544
    Aerodynamically, is 50-50 the best?
    Or is it just whatever gives you the best traction?
    • 28687
    I haven't gotten to the point that weight distribution is a big deal yet but I'd guess it depends on the car and racing surface. At ECTA I'd guess 50/50 might be a good starting point but at speed on the Salt the trick is to keep the drive tires attached to the salt so a bit more rear bias might be helpful. I know some of the racers ballast toward the rear with bolt-on weights as they look for traction.
    • greenjunk
      • Nov 2008
      • 871
      Its aerodynamic driven by vehicle, or at least it should be. if the car has a lot of frontal lift as you accelerate more and more weight will be transferred rearward, leaving the nose light. If you don't have this problem you can run a little more weigh in the rear. I'm 51/49 ish with 500lb lift on the nose and 250lb of downforce on the rear at 200. seanm's caddy is probably 60/40, but has 90,000 lbs of lift at 200mph. :-) your results may vary.
      • GH
        • Jan 2011
        • 370
        I was told to shoot for 51/49, it worked great on the salt, went 248.
          actually, the more on the front you can run the better for yaw stability, once you are fast enough that stability becomes a concern. we run 58% on the front of both of Sicilio's daytonas. we only put as much as necessary on the rear to keep traction, the rest goes forward for stability at speed.
            from what Turk has said over the years, plan on adding a lot of weight.
