I have the same A1000 and Aeromotive filters & regulator setup on my EFI BBF. #10 up and back from sumped stock tank. Like others I change the filters once a year, usually right before DW or a tune up race. No issues with pump life since my very first one in 2002 which didn't like Cali fuel which had alcohol and MTBE's in it then. The news ones (one new and one sapre which I switched in two years ago have been fine with controller or without. I like the 20 gallon stock tank for the range and its under the steel trunk floor which I like in a convertable. New revised stock tank will have #12 from the Aeromotive weld in sump to the pre-filter-pump-post-filter assembly behind and slightly below the rearend housing.
