Re: Junkyard source for Injectors
ehh, remember you'd have to still have boost referencing, so that 87psi fuel pressure now becomes 107psi pressure. Then you have to make sure your pump can flow the required fuel at that pressure. And it's hard on injectors.
Are you still going with MS? I'd get a set of 95s and have a little headroom and not have to jack up the pressure. They're going to cost the same as a set of 60s.
