I'm thinking about mounting a 2006-ish Mustang trans cooler mounted somewhere under the car. They are a plate style, and are pretty long. I could weld some tabs to the subframe connectors to mount one under the passenger seat area. That would keep the lines short and they would not have to run all the way up front like they do now. Then again one might fit well low up front, it would just be a PITA to get it in there.
I thought about using an ac condenser as a giant trans cooler mounted up front. I did that on a Ranger one time. Worked pretty good on it.
[ATTACH=CONFIG]28979[/ATTACH]
Be sure that the inlet/outlet sizes and over all flow area will not be a restriction. My trans builder really pressed on the line size to the cooler too.
I am currently ignoring a screaming deal on a set of new TFS A460 cylinder heads.....
Must. Not. Cave. Like. Being. Married.
Tellin ya man, they are repair parts for the truck. You're saving money! I bet those lame duck old school mafia heads will fix a lot of the "Still doesn't seem quite right" issues you know you are still having with your truck... and you saved so much money with the truck so far that it shouldn't damage it's budget too much. Not much worse than having the D3's rebuilt. (cough... cough)
would it need new pistons? 557" coming our way soon?
Pistons: Maybe not. It really comes down to what your existing piston looks like (mine's a quench killing 0.11" dish) and how much lift you're running. Mine might not even need to be flycut.
Will probably be the last set of heads you will ever have to buy.
I've heard thsi before.. where was it?
Oh yeah!
Ken Kessler: Check it out, my man! This is the Dominator X-10. Thirty inches of thigh-slapping, blood-pumping, nuclear brain damage! Heavy Metal Kid: Bitchin'! Hey, what's it f*cking cost?
Ken Kessler: That's the bitchin' part about it! It don't matter! If you can't afford it, F*CKING FINANCE IT!
[turns it on] Ken Kessler: So what if it's as big as a Subaru and costs as much? You'll never have to trade this in! This is gonna be with you for the rest of your life! And when you die, they can BURY you in it!
