I have done several Mopar 8.75's in the past, but this is my first 8.8.
I would like to get close on the pinion bearing depth the first time with out having to pull the bearing a gazillion times.
I keep running across the number 4.420 (+/-.002") as a total pinion depth spec for 8.8's.
Is that only for factory Ford gears or is it a universal number?
Reason I ask is this:
1.868" = Pinion head (NO shim)
2.554" = Checking dist marked on pinion head
4.422" = would equal no shim needed at all
How often do they require no shim at all?
Strange.
Strange.
