I've been pretty busy with robots, but I did get a little work done on the camper this week. I started on the partition that goes at the bottom front, and covers the water tank, battery, and pump. The original battery was a long skinny one that you can't buy at Walmart, so I decided to move the partition back a few inches, so I could install a normal battery. This means I need to make a sealed battery box too. I finally figured out how to do it---the sealed boxes you can buy are way too wide. I'm going to make a plywood box, with a hinged lid, and weather stripping around the lid. The battery will sit in a plastic battery box I found at walmart, but I"m only using it as a tub to hold the battery and catch any acid that might spill. The old partition was eaten away along the bottom from acid, looks like it was charred by fire, but I guess that's what acid does to wood.
Of course this all led me to have to take out the kitchen side of the camper...I removed the plumbing, sink, and oven. Then I realized the counter top was fastened in pretty well (and at a nice sloping angle, too). I managed to get the cabinet out from under the counter top. Then I got to work removing the counter top--it had a piece of aluminum trim screwed above it around the edge, that pulled off with a lot of force (enough to completely ruin the trim). There was a lot of caulk/sealer/glue type stuff holding it all on. The counter top would still not move. I got one end to wiggle a bit, then yanked and broke that end off. Then I saw the problem. I had wondered what those 7/16" bolt heads were on the outside of the camper...turns out they're 4" long lag bolts, screwed into the edge of the counter from outside the camper, holding the counter top in! idiots....
Anyways, the kitchen is out now, and it looks like it won't really be too hard to fix it. I need a new counter top, and the oven/stove is pretty old and broken looking. New stoves with an oven are $400 or so, and I'm kind of thinking a two burner cook top would do all I need.
so I guess it'll show up later this week. Then I can leave the cabinet as it is, and just make a new counter to go on top of it. I'm debating about the counter, I'm thinking I'll just get some melamine particle board and use that. It's pretty much the same material as "real" countertop, but it's cheap and easy to buy and use. $35 will buy enough for two counters, and I only need one. Also if I screw up, I can make it over again. I should search and search for the correct original speckled pattern Formica...but that ain't happenin.
