Saw some pictures Doc posted on FB. It looks like you're going to larger TB's Doc? The rear one looked like the FAST and the front an Accufab? Was it the camera lens as they seemed to be two different sizes. I like the spacer too.
Someones New EFI Intake Project is well underway
Yes two sizes its what he had, but they are the same CFM the shorter one in front to try to clear the hood. We are just not sure we can get the port taper on it to flow enough but are going to try.2007 SBN/A Drag Week Winner & First only SBN/A Car in the 9's Till 2012
2013 SSBN/A Drag Week, Lets quit sand bagging, and let it rip!Comment
My intuition says that managing airflow into the TB's is likely as important to EFI individual port injection engines as it is to carbed or TBI motors. I regret not trying the air cleaner/tray assembly on mine at the engine dyno. I built an angle into the air cleaner/isolator tray to try and accomodate the hood but it was a big compromise over what I think wold be ideal.
The exact same K&N air cleaner carb inlet set up helped a 496" Pontiac motor and hurt a 525" BBC on the same dyno set-up. Every engine is different and lacking infinite testing and dyno time we all have to make the most educated guess we can.Drag Week 2006 & 2012 - Winner Street Race Big Block Naturally Aspirated - R/U 2007 Broke DW '05 and Drag Weekend '15 Coincidence?Comment
Try and fail happens to me a lot Bill.
I am already making secondary plans if we slow down with it. We do know its got a 8.999999999 in it now just being greedy.2007 SBN/A Drag Week Winner & First only SBN/A Car in the 9's Till 2012
round two. Already had the plenum done; customer scribed the ports and sent it back for finishing. Here ya go Doc 'n Jeff.
Before:
After:
Before:
After:
Work was done by Scott Foxwell took over 5lbs out of it.2007 SBN/A Drag Week Winner & First only SBN/A Car in the 9's Till 2012
Man is that pretty. The radiused runner transitions are works of art. Congrats to Doc on the up-coming HRM feature. Won't they be interested to see the new go fast stuff.Last edited by CDMBill; May 14, 2012, 08:12 AM.Drag Week 2006 & 2012 - Winner Street Race Big Block Naturally Aspirated - R/U 2007 Broke DW '05 and Drag Weekend '15 Coincidence?Comment
Posted by Scott
I can't say as I don't have any before and afters, but I will say that from an area standpoint, there is a night and day difference.
Here are some numbers to ponder:
When I started, I calculated a runner opening size (in the plenum) based on velocity. I made the openings 5.4 sq in.
When the intake came back with the port openings scribed, they were ~4.2 sq in. I had to establish a relatively even taper (in area) from 4.2" to 5.4". Here were the first measurements I took of the runner, starting at the port opening and working toward the plenum in 1" increments (without radius correction):
Port - 4.24
1" - 3.96
2" - 3.88
3" - 3.80
LOL...not looking good. This number is supposed to be getting bigger, not smaller.
Now, the runner has a taper:
Port - 4.24
1" - 4.31
2" - 4.38
3" - 4.42
4" - 4.45
5" - 5.01
Opening - 5.38
It's not an ideal taper. Form the plenum, the port gets small, fast, but there's nothing I can do with that without major reconstruction. Given the limitations of the casting, this is about as good is it can get. You can see by the area increase in the middle of the runner that it's going to move a lot more air and be a lot happier.2007 SBN/A Drag Week Winner & First only SBN/A Car in the 9's Till 2012
Thanks counselor. I am excited about the iconic magazine feature, but wish I had grabbed the elusive 8 second DragWeek pass prior to publication. Otherwise most awesome indeed.Originally posted by CDMBill View PostMan is that pretty. The radiused runner transitions are works of art. Congrats to Doc on the up-coming HRM feature. Won't they be interested to see the new go fast stuff.HOTROD Dragweek Pro Street N/A winner 2007,2011, 2012/ 2nd, 2009
HOTROD Dragweek quickest and fastest naturally aspirated car in any class 2006, 2007, 2011, 2012
FIRST IN THE EIGHTS Legal Pro Street N/A HOTROD Drag Week 2012Comment
Congrats on the pic of your car on the last Page of the latest HotRod.......Originally posted by whichdoctor View PostThanks counselor. I am excited about the iconic magazine feature, but wish I had grabbed the elusive 8 second DragWeek pass prior to publication. Otherwise most awesome indeed.Comment
Thank you TCOriginally posted by TC View PostCongrats on the pic of your car on the last Page of the latest HotRod.......
Camaros forever!HOTROD Dragweek Pro Street N/A winner 2007,2011, 2012/ 2nd, 2009
We'll get that 8.9x slip soon enough.www.realtuners.com - catch the RealTuners Radio Podcast on Youtube, Facebook, iTunes, and anywhere else podcasts are distributed!Comment
Hmmmm,9.12-8.799=0.321 second improvement.Originally posted by CDMBill View Post8.70's I bet a round of beer.
I think I would be buying a round if the changes being made produce that kind of gain!HOTROD Dragweek Pro Street N/A winner 2007,2011, 2012/ 2nd, 2009
You might just be pleasantly surprised, I know I was by the jump in the torque curve all the way across the usable band with the TR.Drag Week 2006 & 2012 - Winner Street Race Big Block Naturally Aspirated - R/U 2007 Broke DW '05 and Drag Weekend '15 Coincidence?Comment
Location of Bungs
Drilling Pilot holes to locate from the inside of port, then Manifold get flipped over Drill Is used in Mill drill chuck then locked down and change to a end mill to make injector hole.
Milling from under so it does not hit the top of intake with the mill.
Action Shot of Doc Mac at work. Asking Is this how Wilson does it?
Presto, Injector bungs! Ready to weld
TheHat, The Dom throttle body holes are to small, so we cut them out at a 12* angle with a inside bore, then went all the way around with a mill tool and will blend from there. Scott is sending us our spacer we should be threw pretty quick and just waiting on the lifters to come back to try it out.
Last edited by JeffMcKC; May 21, 2012, 11:10 AM.2007 SBN/A Drag Week Winner & First only SBN/A Car in the 9's Till 2012
