Well i did it now
  • quick 52
    • 1579
    Originally posted by cstmwgn View Post
    There you go Dale - those would look AWESOME on your F1!
    with that rim sticking out pass the tire like that u could run it on rails... I like the tire wider than the rim
    Drag week 2009 Quickest street rod
    Drag week 2010 Quickest street rod
    • tonycpe
      • 16
      NIce job ! I like fast trucks. any more pics of the truck and under the hood? What track do you race at?
      • quick 52
        • 1579
        Here is a couple pic
        • yellomalibu
          • 3631
          Ideally, I like to have the tread width be the same as the rim width. On lower profile tires, the look gets exaggerated, quick!
          I didn't even like the look of the stock Corvette tire/wheel combo in the 70's, when they used an 8" rim with a relatively narrow tire. The only reason it worked, however, was because of the 70 aspect ratio.
          '69 - '72 8" rim 205/70/15
          '73 - '77 8" rim 215/70/15
          Using that same Corvette chart I was looking at, the factory put a 315 on an 11" wheel ('96 GS coupe), and only recommended the size vary by one size larger or smaller.
          http://www.docstoc.com/docs/10209773...For-stock-size
          The lower the profile of the tire (aspect ratio) the more critical tire size becomes.
          • quick 52
            • 1579
            in the shop today got the other tub welded in and ground tomorrow will remove fenders and bondo
            • quick 52
              • 1579
              Here's some pic of the truck tub project
              • quick 52
                • 1579
                #37
                more pic
                • quick 52
                  • 1579
                  #38
                  going to try a test panel tonite or tomorrow want to spray new base paint on half old panel I cut out then clear all and see if it will match if so it will make life a lot easier
                  • silver_bullet
                    • 24509
                    #39
                    damn that looks great!!
                    Patrick & Tammy
                    • quick 52
                      • 1579
                      #40
                      is there a way to move this thread to project
                      • R Munch
                        • Jan 2013
                        • 240
                        #41
                        Maybe if the wife comes out and helps it wont have to move to the project thread just GET ER DONE
                        • quick 52
                          • 1579
                          #42
                          Did get at it today primed the inside hope to be ready for some paint in a week will put up some pic later
                          • quick 52
                            • 1579
                            #43
                            worked on the old farm truck today here's some pic's..
                            • quick 52
                              • 1579
                              #44
                              here's a pic of the truck looks like a old mini semi
                              • quick 52
                                • 1579
                                #45
                                worked on the truck today didn't like the sides of the bed from the first time painting it so after 13 years I got around to fix it plus welded a stake pocket in the middle of the side looks like it needed one
