Getting ready to order fuel system parts ASAP . . .
Minimum specs:
1. Must pass NHRA tech
2. Must hold up for thousands of street miles
3. Must flow enough fuel at EFI pressures (43+ psi) to run 10s in a ~3,500lb car with some margin for error (.65 BSFC/700+ hp)
4. Must be somewhat alcohol compatible (maybe not for this year, but who knows what the future holds)
5. Hopefully won't cost an arm or a leg.
Any opinions or experience?
What about Push-lok?
Steel hard lines (I haven't really found anything with enough OD yet?) Something else?
Where would YOU buy it?
Minimum specs:
4" tall 2" diameter iron pipe with end caps tapped with brass fittings. Discreetly bolted to the firewall.
