Re: TheSilverBuick's 1967 Thunderbird
Put the new alternator in, the voltage fluctuation is still there >
BUT it seems a lot of the actual signal noise that was transfering to the system seems to be gone (my duty cycle and pulsewidths appear to be waaay more stable) PLUS I have one full volt more across the rpm range from the old alternator, which makes me feel better. Seems to be running pretty good too
Idles at 650rpm in neutral, 475-500rpm in gear, has a slight stumble snapping the throttle, but will accelerate. I think tomorrow I'm going to swap out the voltage regulator with another one I have and I'm going to do some re-plumbing of the headlight door vacuum system and go for some test drives to see if I run into any hiccups. I'd really like to drive this car out of town on my next trip out, it's spent at least a year confined to Ely and work.
But the real shocker was how much crud was inside the tank
I'd have to check where I got my Argon/CO2 bottle from, plus I need to look in the scrap bins around work.
