    #1456
    I think standing, you can duck and weave easier, laying on your back all you can do is watch it hit you while pissing yourself...
    • NewEnglandRaceFan
      • Jun 2013
      • 2991
      #1457
      ya the starter gets to fall 5-6' and hit your toe's.. as you freak and the car guy in you, try's to save the starter from impending doom..
        • 28707
        #1458
        I got a chuckle from that one. As I've aged and stuff heals slower I've learned to let the starter (or whatever) fend for itself. I'll fix the solenoid (or whatever) later.
          #1459
          For sure.. Can buy another starter, or fix it.. An owie just lasts too long at our age!
            #1460
            Scott - the prices of portable lifts are coming down - many tire shops have them now - they lift from the middle of the underside of the car so both front and rear axles and areas near them are exposed. No good for exhaust or transmission swaps on a RWD car, but for tires, brakes, suspension - or under the engine work - they're great - and totally portable - with no holes in the concrete required - I think they lift the car up around 2-3 feet so ceiling clearance in a standard garage is no problem. I think you can pick one up now for 2 grand or a bit less.
            here's one:
            http://www.gregsmithequipment.com/At...e-Scissor-Lift
              #1461
              My $15 junkyard sway bar from a '76 Monte Carlo now on the Caprice. It's hanging a bit low for me. I haven't test drove it yet.
                • 6529
                #1462
                Did you drill the holes in the control arms or where they already there?
                  #1463
                  Drilled them. I used the U shaped brackets that came off the Monte as well. The trailing arms on the Monte were drilled as well. I did spend about $10 in new grade 8 hardware.
                  • langleylad
                    • Jul 2008
                    • 1694
                    #1464
                    $10 well spent , thanks for the wrecking yard pics by the way
                      #1465
                      Since I broke three of the four bolts that holds the bar to the brackets, not a lot of choice. The holes were big enough to move up to 7/16th bolts from the rusted 3/8th stuff they had. I am not sure how much pressure gets put on the rear sway bar, but didn't want to risk anything.
                        • 6529
                        #1466
                        Did the U shape brackets detrimine the hole location? I ask because if you can lower the front hole and or raise the back hole it might raise the bar closer to the rearend? I will have to look under my mustang but I think the bar is above the bottom of the rear, Could the holes be moved farther back?
                          • 32275
                          #1467
                          are your lower arms boxed?
                            #1468
                            The bolt holes in the U brackets have staggered bolt holes. If I tilted them in the arms instead of parallel to the bottom of the trailing arms, the bar would've been closer to the bottom of the rear differential by maybe an 1 inch.
                              #1469
                              Nope. Original ones. These brackets will help stiffen them somewhat.
                                #1470
                                Here it is on it's wheels.
                                Took it for a spin. Not many curvy roads around here. Not sure if it is an improvement. It still takes corners like an elephant on an ice rink.
                                Took a few pics of the car. Didn't even bother washing the car first. The body side molding blew off the car last time I went anyways. Still have to put it back on. The car's rake got a little steeper over the last couple years too.
                                Here you can see the sway bar in relation to the differential.
