Well let it sit over the week I was gone and came back and the battery was still at 12.96V so if there is a drain, it's microscopic.
Found a vacuum hose disconnected so I plugged that in and I also dumped a quart of ATF into the oil to thin it out and make sure it got everywhere it needed to.
Started up just fine and the knocking sounds were all gone. However the ticking/clanking sounds from valvetrain were still there and maybe even louder than before. I think it's because I swapped the heads side to side to eliminate the EGR completely (one of the CNC ported heads has the passage drilled) since it pulls from only a single side and that changed the valve clearance. I'll pull the valve covers and relash the valves and check that I have oil getting up to the valvetrain.
I'm still chasing why the Autometer tach is not working as I've tried plugging it into the ignition module directly and the ECM Tach output and nothing comes up on the gauge.
This means the carshow this weekend is a bust but I'll keep plugging away at getting it all fixed. There's another show in Oct and if it works well a Buick show in Denver later this month I can try to hit.
