Toymakers Twin Engine Dragster.......Not just to look at!
  • Toymaker
    • Aug 2009
    • 106
    #61
    Re: Toymakers Twin Engine Dragster.......Not just to look at!
    I understand what your saying but............IVO had his 2 450 Cubc Inch Nail Heads hooked up this way, power I'll never match. My feeling is that all the REV (or what I call a slave) engine is doing is assisting the main engine, not transfering full power to the rear end thru the main engine ring gear or ring gears as ea flywheel will have double gears installed. It's like a grammer school science project, thats my hypothesis (I think thats the word I'm looking for) and we will see. No turning back now ;D Rocky
    • yannick
      Tire Chirper
      • Aug 2010
      • 62
      #62
      Well said and thumbs up on your fab work. There is that extra special feeling when building something this epic with your fingers crossed at the end!
      I'm exited for you on this great project.
        • 16031
        #63
        Great work - if every "inventor" knew what the end result would be before he started - we would be without many great inventions!
        Worst case scenario if the ring gears turnout to be problematic, you could rig up something using a 4x4 transfer case chain drive or similar. What do the multi engine tractor pullers use?
        • Toymaker
          • Aug 2009
          • 106
          #64
          I believe they use special gear boxes like Garlits tried on his "Side Winder" but I'm not sure.
          • Toymaker
            • Aug 2009
            • 106
            #65
            Yep, it's on the ground and ready for the frt axle build but here's the way we got here from where we last left off.
            Lee welded what he could after I completed the front frame bracing.
            The RH rear end bracket was a little more than a 1/2 RD cut as it had to follow the contour of the center section, so I make a little "Widget" to transfer the shape to the plate. Mark your project with line to follw to keep the shape transfer correct. I've used this metHod before on wheel tub projects and works really well and I have layout dye but a good "Magic Marker" works great!
            Once I was happy with the rearend alignment the rearend housing was welded to the brackets after they were bolted to the frame, I used 3/8" bolts for now but they will be increased to (4 per side) 7/16" when finished.
            My alignment tool is all scrap pieces including some old pistons;)
            With this all done I cut some old axles mounted the wheels, and put her on the ground!
            And this ones for you Tom:D
              #66
              bad ass! really like the HD rims up front..
              • Toymaker
                • Aug 2009
                • 106
                #67
                Another part of the build done, I machined the frt kingpin bosses and bent the axle for the car today. I'm the luckiest guy in the world as I thought I trashed the front axle when I cut the wrong King Pin inclination But luck would have it that I was using the bottom of my 48 F1 axle as a jig so I recut the fishmouths and it fit the Top perfect, should go buy some Lotto tickets:D Original Plan........
                Revised;).......
                Loaded up the car after we finished the front end this week and my son took it to Fomosa today, I can't wait to get there tomorrow night!
                • Weldangrind
                  • Nov 2008
                  • 744
                  #68
                  The dragster looks really good assembled. 8)
                  What sort of machining did you need to do for the kingpin bosses? I get that you had to bend the tube to meet the shape of the F1 axle and fishmouth the ends, but I'm not sure what was machined. I presume you're talking about bushing installation, but I'm not sure.
                  Good bit of luck on being able to use the top side of the F1 axle. ;D
                  EDIT: I'd love to see some detail of the final front axle mount.
                  • Toymaker
                    • Aug 2009
                    • 106
                    #69
                    I had to machine the kingpin boss' (the part the kingpin actually goes thru) out of some round bar. I'll post a followup next week after we get done with the March Meet. I want to thank all the BangShift member support, your interesrt as well as the HAMB has helped me get this far! Rocky
                    • Brian Lohnes
                      Administrator
                      • 18784
                      #70
                      Rocky, thanks for sharing this project with US!
                      Have fun at the MM!!!!
                        • 16031
                        #71
                        This thing is flippin sweet - I'm still amazed at the scale of projects some folks take on in their spare time! Inspirational!
                          #72
                          It looks just as neat in person. I look forward to seeing it running.
                          • mustang13
                            • 3379
                            #73
                            Great work Rocky.....and is that a second FED I see in this pic?
                            Jeremy George in Windsor NY
                            • Toymaker
                              • Aug 2009
                              • 106
                              #74
                              Haven't got much accomplished since the MM, DANG Chad keeped me out of the shop watching the the MM Finals : but we'll get back after it soon!
                              Yep, my wifes car, that's my story and I'm sticking to it ;D The car is a late 60's Logghe car I believe and also apart right now, here's a photo of it @ Eagle field in October.
                              • Toymaker
                                • Aug 2009
                                • 106
                                #75
                                Great meeting ya & putting a face to your screen name and that makes 2 of us.
