Can you run the Gen III/IV coils with power to the control side (5V TTL) but no power to the 12V side? Reason is it's simpler to control a group of 3 (4 for the V8 guys) coils through the power side when occilating back and forth between different "banks" of coils if the ICM drives a waste spark but you have all the sensors (but not the ECM) to control sequential.
For example, my OBDII controll 4.1L Buick V6 uses the stock L67 ICM that fires the GM twin tower coils. It's been proven by several people that running a sequential/distributor ignition system is worth power. Theory is that firing one set backward, strap to electrode, doesn't light the mixture off as well and the chamber design doesn't do any favors to the system either. Since the ICM controls the coils in 1/4, 6/3, and 5/2 pairs, use the ICM signal through a regulator to drive the TTL side but use the cam sensor sync to control if it was the 1-6-5 "bank" or the "4-3-2" bank. Following?
