Originally posted by BBR
View Post
The dreaded bounce effect, néed to slow down the rear end. Usually your issue means the suspension hits the tire really hard, e.g. Separation and then tire rebounds after the compression unloading the car enough to lose traction. You seem to have plenty of rotation and you may need to slow the front end down too. If it tops out too quick you can have the same issue.
All of that is why the DR cars often need double adjustable shocks to manage the suspension reaction more effectively. Is it worth chasing a bit of ET for the cost is another question. If you shorten the IC by lowering the front mounting point of the upper control arms the effect may be exacerbated.
