+ Reply to Thread
Page 21 of 30 FirstFirst ... 11 17 18 19 20 21 22 23 24 25 ... LastLast
Results 201 to 210 of 295
  1. #201
    Legendary BangShifter BBR's Avatar
    Join Date
    Oct 2007
    Location
    Amarillo, Texas
    Posts
    5,751
    I'd leave it looped because the plugs I have used were of questionable quality (developed cracks very quickly) and looked to be a potential point of failure.
    1983 Mustang GT 545/C6 - 10.56 @ 127.38 - www.foureff.com - Four Eyed Fords Forum
    Drag Week 2012 - Street Race BB N/A runner-up
  2. #202
    Hero BangShifter Russell's Avatar
    Join Date
    Oct 2009
    Location
    Wendell, NC
    Posts
    2,175
    Quote Originally Posted by BBR View Post
    You mean the rubber caps that go over the water pump? I was going to red neck engineer that and get a pipe plug for the intake, My new intake does not have the elbow on it.
  3. #203
    Join Date
    Oct 2009
    Location
    Wendell, NC
    Posts
    2,175
    Got my new used intake on the car last night and the dissy dropped back in. Now just the carb linkage, wires etc. Took way longer that it should have. I dropped one of the thermostat housing bolts down the dissy hole. Luckly I was able to get it out with a magnet. Then I had to mess with oil pump rod for a while to get it re seated the thing that holds it in place is not in the right place. The 1/4 is haveing Sunday afternoon testing from 2-8. Dad said he wanted go with me.
    I picked up a used wide band O2 off craigslist (I hope it works) way more involved than I would have thought to install. Is an intake manifold stud bolt a good ground?
  4. #204
    Lord God King BangShifter TheSilverBuick's Avatar
    Join Date
    Nov 2007
    Location
    Ely, NV
    Posts
    16,844
    On a wide band O2 sensor, ground the heater ground wire away from the other O2 ground wires (or any other sensitive electronic grounds). I grounded my heater ground to the firewall and grounded the sensor to the same place as the MegaSquirt. In your case I'd make the sensor ground the same place or as close to the gauge as possible and make the heater ground away from that. I'd use the "on the engine" or "off the engine" mentality. If it's just a gauge I'd ground the heater to the engine (intake is good) and the sensor to the body (or same place as the gauge).
    " Because your cylinder heads have to babysit an angry mob of pumping cylinders.."
    Drag Week 2011 - BB N/A - 1977 Skylark w/455 EFI and TKO-600!
    Drag Week 2012 - Street Race BB N/A - DNF on Day 6 - 1977 Skylark w/455 EFI and TKO-600!
  5. #205
    Join Date
    Oct 2009
    Location
    Wendell, NC
    Posts
    2,175
    Thanks that helps alot. Any reason i should not use the old radio wires for the key on 12 volt source?
    Got the new intake on, I never could get the dissy dropped in on the right tooth, after too mainy failed attempts i gave up and just mover the wires one post over. Sounds pretty good. I really need to do something about the extream amount of advance.
    Car is on the trailer fingers crossed for good day at the 1/4
  6. #206
    Join Date
    Oct 2009
    Location
    Wendell, NC
    Posts
    2,175
    I had a great afternoon at the track! Trailered home a car still in one piece! Exceeded my speed goal! Full report tomorrow w/ video!
  7. #207
    Join Date
    Oct 2007
    Location
    Wilmington, NC - by the Atlantic
    Posts
    13,201
    Russell - I posted the promised trip report in the "General" section, if you want to add the video there (I said you would).
  8. #208
    Join Date
    Oct 2009
    Location
    Wendell, NC
    Posts
    2,175
    Made 8 pass:
    Off the trailer 14.79 @ 99.38 (breaking up)
    2nd pass Best ET of the day 14.19 @ 98.64 (still not running right)
    Four passes not with talking about. Dumped a couple gallons of race gas durring this time. Not sure if the volume or the 112 made it run better!
    7th pass 15.73 @ 100.31! as seen here:
    We watched the fast cars for a while let the car cool for 50 min. Then made a good clean pass of
    14.34 @ 102.23!
  9. #209
    Join Date
    Oct 2007
    Location
    Posts
    13,201
    Traction. Wazzat??!!
  10. #210
    Join Date
    Oct 2009
    Location
    Wendell, NC
    Posts
    2,175
    Is there a size limit on post?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
