1979 Mercury Capri
    • 6528
    #211
    3/4 mark my GPS quit and Held at 122 but the car was running good and the tach was still climbing. I decided to hold wide open and when I got my slip it read 143.89622 MPH! Makes me wonder if it would be faster without the direct drive fan, power steering, and smog pump, maybe with a little more gear, or a round or two out of the springs.
    The concrete in Ohio is so nice I now understand why Joe kissed it! But I would take the bumps and the 2 hour drive back any day!
    So what is next for the Capri? 3.73 and DR then take it back to the 1/4. If I cannot find a cheap 8.8 with a trac loc it will get a 7.5 and it will be Miller time!
    143 for less than 3k not bad!
      #212
      Great work!
        • 6528
        #213
        Thanks! Other than seeing what it will do on the 1/4 I have a lot of soul searching to do with this and the rest of my cars. I am going to post a poll.
          • 32257
          #214
          that is an awesome illustration of a excellent job
          it's also a good example of project creep
            • 6528
            #215
            Lol which part are you calling project creep? taking it to the drag strip? Not that far out of line of the orignal goal LSR car. The creep would be if I wanted it to look good or make it a street car, not there yet.
              • 11725
              #216
              Congrats!! 143 is movin' on!
                • 6528
                #217
                Thanks! 10.50's is very impressive! Would have look in the rule book but I bet it would not take much to get your car to tech to 150 and it should do ever bit of it! Its "only" 1200 miles
                  #218
                  There is a "Texas Mile" isn't there?
                  • t russell
                    Tire Chirper
                    • May 2011
                    • 87
                    #219
                    So the capri is doing a fine job time for cage/seat etc
                      • 6528
                      #220
                      There is, but then i would less likely to be able to hang out w/a BBR! From what i have heard you i think you could run all out at TX as it sits.
                        #221
                        that was my take on the rules... and it's always funny to hear the so awesome Georg Ray "Outlaw track would be awesome" run at your own risk, until the Timing Association guys rag on safety equipment. Dang, I'm in a mood tonight. Nevermind.
                          #222
                          hell yes! sorry, I forgot what this thread was about!!
                          I think I have 4.10's for a 7.5, lincoln lock that sucker. Lots of 4 cyl Rangers came with 4.10s or 3.73's, and a spool or welded spider gears will hold up I bet. I tried to find a spool a while back, I suspect the Pinto dirt track guys may have some insight into that.
                            • 6528
                            #223
                            There are only 6 bolts, parking breaks and hose holding the rearend in the car. I think its easier to swap the hole thing than change the gears i think some of the 4 cylinder cars had 3.73
                              #224
                              Perspective... Not as hard as they are made out to be..
                              Just need to get your mesh, coast and power marks right with the fewest tearaparts.. For some reason, shims do not like being banged on... I set up rears for flatbed's 14 bolt, 3-12 bolts and several derby rears with just chisels (dulled ones) and brass drifts..
                              So far they all are still in use.. Helps to have a dial indicator...
                              Just don't nick anything or set it up tight nor loose..
                              I set up the derby rears with no slack between forward and reverse because they get slap shifted. Teeth less likely to be snapped off..
                              Use the shims that came with your housing will probably get you the closest to correct.. But I would try the ones that came with the gears and make sure it meshes correctly, before going to the ones from the housing..
                              The brass drifts I use were ground ar 45* to one side and one is pencil thin. The others are about 1 inch..
                              I was shown how by an old timer, without the dial indicator.. Once you get the feel.. Pretty simple..
                              • 1trickpony
                                • 1102
                                #225
                                If you do a gear swap and it's not to much trouble, could you do a how to or a what's what of the install? I have never personally done one and rather not pay someone to do it.
                                Jeff
                                Follow My Build
